reflection pass question
Hello
I have a quick question about reflection passes in houdini.
Lets say i'm reflecting some geometry onto a large environment . Does the large environment need to be subdivided to get a good quality reflection? I noticed that my reflection pass is not that accurate or straight if i don't subdivide the mesh its reflecting on first.
I can't really recreate the issue since its a work file but I just wanted to get some input on this. Is this a common thing to do? It gets really slow and painful when I have to subdivide all my geometry in my scene just to get a good reflection pass.
Is there a better way to do this ?
Thanks
if you only have a flat surface (like a mirror) then adjusting geometry normals should be good enough (default normals smooth any corners < 60 deg). if it's a more complex shape then naturally more polygons = more accurate reflections.
25 minutes ago, isah_voodoo said:
@davpe Thank you. Thats good to know.
I was hoping that the "Render Polygons As Subdivison" on the geo node would do the trick, but apparently not.
Thanks
It does the trick if your mesh subdivides nicely...
