DonRomano Posted August 27, 2020 Share Posted August 27, 2020 Hey guys, I need to create some empty files with Python, and when I try with : open("my_file.py", "w").close() When I open the file with hou.hipFile.load() or with a Houdini subprocess, I get an error (Error : Unexpected end of hip file). It seems normal to me because I assume Houdini put some data even when the file is empty, but I'd like to know if someone here knows how I can create en empty houdini file, without having to open it manually and save it to override the existing bugged file. Cheers, Quote Link to comment Share on other sites More sharing options...
khiladisngh Posted May 19, 2021 Share Posted May 19, 2021 Try using this command hou.hipFile.clear() You will find more about it here: hou.hipFile Quote Link to comment Share on other sites More sharing options...
