Moving geometry boolean
gangland
Hello guys i having trouble while doing this process:
I use an incoming modelled piece geometry to boolean an moving alembic.
the ideia is one of the debris piece fall with an normal gravity.
while the moving geometry stick with the booleaned shape.
i was messing with point deform nut no luck at all.
i dunno if it a bit complicated if need i can provid an simple setup of the question.
thx
