Problems with Mouse Event Handler when Duplicating Node ( Asset )
gemini
    In H18 when a node ( which type is a digital asset ) is duplicated this happens:
Any Ideas?
Thanks in Advance !
Traceback (most recent call last):
  File "Mouse Event Handler", line 19, in <module>
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\nodegraph.py", line 99, in handleEvent
    handler_coroutine.send(uievent)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\nodegraph.py", line 165, in handleEventCoroutine
    pending_actions)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\nodegraph.py", line 720, in handleEvent
    self.applyAdjustments(uievent)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\nodegraph.py", line 929, in applyAdjustments
    connect_outputs_to_multi_inputs = False)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\hou.py", line 10017, in copyItems
    return _hou.Node_copyItems(*args, **kwargs)
OperationFailed: The attempted operation failed.
Warning:     Problem while synchronizing child node:
             Warning:     Too many elements found for parameter "/obj/sphere_object1/vdbPlacer_001/bound1 Bounding Type".
        [/obj/sphere_object1/vdbPlacer_001/bound1]
Warning:     Too many elements found for parameter "/obj/sphere_object1/vdbPlacer_001/bound2 Bounding Type".
        [/obj/sphere_object1/vdbPlacer_001/bound2]
