Gayane Posted September 9, 2020 Share Posted September 9, 2020 (edited) I tried to create a nebula and came across 2 problems. 1. I cannot see any colors, when I try to add them to particle cache. (1 Photo) 2. When I try to cache 6 frames of particles, Houdini only shows 1 frame of it, the rest is blank like in the second photo. How can I fix that? Edited September 10, 2020 by Gayane Quote Link to comment Share on other sites More sharing options...
duveil Posted September 10, 2020 Share Posted September 10, 2020 for your first question did you tried to fit the age attrib. I can check your hip file for your second question Quote Link to comment Share on other sites More sharing options...
Gayane Posted September 10, 2020 Author Share Posted September 10, 2020 (edited) 43 minutes ago, duveil said: for your first question did you tried to fit the age attrib. I can check your hip file for your second question I solved the cache problem... But I have problem with color node. Can you check what's wrong with it? I managed to give color ones, but when I checked it again, I couldn't see any color. Thank you! nebula_12.hipnc Edited September 10, 2020 by Gayane Quote Link to comment Share on other sites More sharing options...
duveil Posted September 10, 2020 Share Posted September 10, 2020 Your scene works. I just opened it and cached the missing files and color is changing according to your age attrib during those 6 frames. I think you need to try in a brand new scene. Maybe some user settings are messed up. Quote Link to comment Share on other sites More sharing options...
Gayane Posted September 10, 2020 Author Share Posted September 10, 2020 2 hours ago, duveil said: Your scene works. I just opened it and cached the missing files and color is changing according to your age attrib during those 6 frames. I think you need to try in a brand new scene. Maybe some user settings are messed up. Thanks! I think so, 'cause in new scene everything works. Quote Link to comment Share on other sites More sharing options...
