Age attribute unseen + cache problem
Gayane
I tried to create a nebula and came across 2 problems.
1. I cannot see any colors, when I try to add them to particle cache. (1 Photo)
2.   When I try to cache 6 frames of particles, Houdini only shows 1 frame of it, the rest is blank like in the second photo. How can I fix that?
Edited by Gayane
  On 9/10/2020 at 8:49 AM, duveil said:
for your first question did you tried to fit the age attrib.
I can check your hip file for your second question
I solved the cache problem...
But I have problem with color node.
Can you check what's wrong with it? I managed to give color ones, but when I checked it again, I couldn't see any color.
Thank you!
nebula_12.hipnc
Edited by Gayane
  On 9/10/2020 at 10:08 AM, duveil said:
Your scene works. I just opened it and cached the missing files and color is changing according to your age attrib during those 6 frames. I think you need to try in a brand new scene. Maybe some user settings are messed up.
Thanks! I think so, 'cause in new scene everything works.
