Hscript In Functions
Dries
string tc() {
	d = padzero(20,3);
	return d;
This is what I get:
/obj -> echo `tc()`
3
/obj ->
Can I not use hscript commands in a function then?
[sOLVED]
You have to declare your variables Dries!
string tc() {
	string d = padzero(20,3);
	return d;
:blush:
Duh, didn't you know beforehand you were going to find the solution right after you posted the question??
Thanks, very much appreciated.
D.
Thanks for your understandig edward :-)
While I can get away with this simple function to generate a timecode to us in a Font COP, don't you think it would be a good idea to have $TC next to $T and $F as well?
for 24 or 25fps timecodes it is simple enough, but there are also dropframe timecodes and PAL/NTSC issues...
Tip for H9?
D.
