Librarian Posted September 21, 2020 Share Posted September 21, 2020 Following some tutos ..Don't see and understand properly maybe this spinets .. Isssue.hiplc Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted September 21, 2020 Share Posted September 21, 2020 Hi Librarian ! I'm guessing your issue is that the attribwrangle4 node doesn't output anything ? If that is so, then your issue is with the "|+" conditional operator I don't know what it is, but I assume you want to isolate the points that has the same value as the current loop of your foreach_end1 So replacing the |+ with != should work If the attribute pairID of the current point is not equal to the current loop iteration value, then remove it Hopefully that fixes your issue ! Otherwise, please elaborate Quote Link to comment Share on other sites More sharing options...
Librarian Posted September 21, 2020 Author Share Posted September 21, 2020 @Alain2131 Thank You Quote Link to comment Share on other sites More sharing options...
