Problem creating and saving multiple bezier curves
  With the following code, I can write out a single bezier curve but anything more than one, the second bezier curves are not in the bgeo file being written out. The point count indicates that it is aware of additional points associated with the second curve.
#include <string>
#include <GU/GU_Detail.h>
#include <GU/GU_PrimRBezCurve.h>
#include <UT/UT_Version.h>
#include <GEO/GEO_Point.h>
#include <OpenEXR/ImathVec.h>
#include <vector>
typedef std::vector<Imath::V3d> V3dContainer;
void create_single_bezier_curve(const std::string& bgeo_filename)
    GU_Detail    gdp;
    V3dContainer cvs;
	cvs.push_back(Imath::V3d(0,0,0));
	cvs.push_back(Imath::V3d(1,1,0));
	cvs.push_back(Imath::V3d(2,1,0));
	cvs.push_back(Imath::V3d(3,0,0));
	GA_Size num_points = cvs.size();
    for ( size_t i = 0; i < num_points; ++i )
    	GA_Offset pt = gdp.appendPointOffset();
    	gdp.setPos3(pt,
    			cvs[i][0],
				cvs[i][1],
				cvs[i][2]);
    GU_PrimRBezCurve* bezier_curve =	GU_PrimRBezCurve::build(&gdp,num_points);
	if (bezier_curve)
			bezier_curve->setVertexPoint(i,gdp.pointOffset(i));
		gdp.save(bgeo_filename.c_str(), NULL);
void create_multilpe_bezier_curves(const std::string& bgeo_filename)
    GU_Detail    gdp;
    V3dContainer cvs;
    // Curve 0
    // Curve 1
	double y_offset = 2.0;
	cvs.push_back(Imath::V3d(0,0 + y_offset,0));
	cvs.push_back(Imath::V3d(1,1 + y_offset,0));
	cvs.push_back(Imath::V3d(2,1 + y_offset,0));
	cvs.push_back(Imath::V3d(3,0 + y_offset,0));
	cvs.push_back(Imath::V3d(4,0 + y_offset,0));
	// Store all the points
    	gdp.setPos3(pt,
    			cvs[i][0],
				cvs[i][1],
				cvs[i][2]);
    // Setup curve 0
	GA_Size num_points_curve_0 = 4;
	GU_PrimRBezCurve* bezier_curve_0 = GU_PrimRBezCurve::build(&gdp,num_points_curve_0);
	if (bezier_curve_0)
		for ( size_t i = 0; i < num_points_curve_0; ++i )
			bezier_curve_0->setVertexPoint(i,gdp.pointOffset(i));
    // Setup curve 1
	GA_Size num_points_curve_1 = 5;
	GA_Offset curve_offset_1 = 4; // because the first 4 points is for curve 0
	GU_PrimRBezCurve* bezier_curve_1 = GU_PrimRBezCurve::build(&gdp,num_points_curve_1);
	if (bezier_curve_1)
		for ( size_t i = 0; i < num_points_curve_1; ++i )
			bezier_curve_1->setVertexPoint(i,gdp.pointOffset(i+curve_offset_1));
			// bezier_curve_1->setVertexPoint(i,curve_offset_1);
int
main(int argc, char *argv[])
    create_single_bezier_curve("single_bezier_curve.bgeo");
    create_multilpe_bezier_curves("multiple_bezier_curves.bgeo");
    return 0;
