nicholas_yue Posted September 23, 2020 Share Posted September 23, 2020 Hi, With the following code, I can write out a single bezier curve but anything more than one, the second bezier curves are not in the bgeo file being written out. The point count indicates that it is aware of additional points associated with the second curve. #include <string> #include <GU/GU_Detail.h> #include <GU/GU_PrimRBezCurve.h> #include <UT/UT_Version.h> #include <GEO/GEO_Point.h> #include <OpenEXR/ImathVec.h> #include <vector> typedef std::vector<Imath::V3d> V3dContainer; void create_single_bezier_curve(const std::string& bgeo_filename) { GU_Detail gdp; V3dContainer cvs; cvs.push_back(Imath::V3d(0,0,0)); cvs.push_back(Imath::V3d(1,1,0)); cvs.push_back(Imath::V3d(2,1,0)); cvs.push_back(Imath::V3d(3,0,0)); GA_Size num_points = cvs.size(); for ( size_t i = 0; i < num_points; ++i ) { GA_Offset pt = gdp.appendPointOffset(); gdp.setPos3(pt, cvs[i][0], cvs[i][1], cvs[i][2]); } GU_PrimRBezCurve* bezier_curve = GU_PrimRBezCurve::build(&gdp,num_points); if (bezier_curve) { for ( size_t i = 0; i < num_points; ++i ) { bezier_curve->setVertexPoint(i,gdp.pointOffset(i)); } gdp.save(bgeo_filename.c_str(), NULL); } } void create_multilpe_bezier_curves(const std::string& bgeo_filename) { GU_Detail gdp; V3dContainer cvs; // Curve 0 cvs.push_back(Imath::V3d(0,0,0)); cvs.push_back(Imath::V3d(1,1,0)); cvs.push_back(Imath::V3d(2,1,0)); cvs.push_back(Imath::V3d(3,0,0)); // Curve 1 double y_offset = 2.0; cvs.push_back(Imath::V3d(0,0 + y_offset,0)); cvs.push_back(Imath::V3d(1,1 + y_offset,0)); cvs.push_back(Imath::V3d(2,1 + y_offset,0)); cvs.push_back(Imath::V3d(3,0 + y_offset,0)); cvs.push_back(Imath::V3d(4,0 + y_offset,0)); // Store all the points GA_Size num_points = cvs.size(); for ( size_t i = 0; i < num_points; ++i ) { GA_Offset pt = gdp.appendPointOffset(); gdp.setPos3(pt, cvs[i][0], cvs[i][1], cvs[i][2]); } // Setup curve 0 GA_Size num_points_curve_0 = 4; GU_PrimRBezCurve* bezier_curve_0 = GU_PrimRBezCurve::build(&gdp,num_points_curve_0); if (bezier_curve_0) { for ( size_t i = 0; i < num_points_curve_0; ++i ) { bezier_curve_0->setVertexPoint(i,gdp.pointOffset(i)); } } // Setup curve 1 GA_Size num_points_curve_1 = 5; GA_Offset curve_offset_1 = 4; // because the first 4 points is for curve 0 GU_PrimRBezCurve* bezier_curve_1 = GU_PrimRBezCurve::build(&gdp,num_points_curve_1); if (bezier_curve_1) { for ( size_t i = 0; i < num_points_curve_1; ++i ) { bezier_curve_1->setVertexPoint(i,gdp.pointOffset(i+curve_offset_1)); // bezier_curve_1->setVertexPoint(i,curve_offset_1); } } gdp.save(bgeo_filename.c_str(), NULL); } int main(int argc, char *argv[]) { create_single_bezier_curve("single_bezier_curve.bgeo"); create_multilpe_bezier_curves("multiple_bezier_curves.bgeo"); return 0; } Quote Link to comment Share on other sites More sharing options...
symek Posted September 25, 2020 Share Posted September 25, 2020 Sorry, no time to look into your example, but this code used to worked: Quote Link to comment Share on other sites More sharing options...
