Make non-HDA out of an HDA instance?
Krion
Hi guys,
Was wondering how you can convert an object HDA instance into a normal object node?
So the parameters become normal spare parameters, thus editable in Edit Parameter Interface instead of Type Properties.
Would like to keep the keyframes and all in tact, so basically disconnect the instance from the HDA.
Thanks for the help
Edited by Krion
You'll need to use Python for that. You should get most of it working with a few steps:
- create an empty subnet
- copy all the parms from the OTL to your subnet with parmTemplateGroup
uiparms = sourcenode.parmTemplateGroup()
destinationnode.setParmTemplateGroup(uiparms)
- copy all the nodes from your OTL to your subnet with hou.copyNodesTo()
- to copy the keyframes, you have parm.keyframes() and parm.setKeyframes()
hope that helps
  • 2 weeks later...
