Ramps on vector attributes
valorSix
Hello I have a question about the ramp function .
I understand that the chramp function looks for a 0-1 value but what does it mean when i provide it with a vector attribute like @P ?
If I have a grid and use this expression:
f@active = chramp("active", v@P, 0);
v@Cd=@active;
This will return a gradient striped pattern on my grid. But why ? I have not provided any 0-1 value here only the values of each point position. Is the chramp function trying to convert this into float 0-1 values ?
Thank you
ramp_vector_attrib.hipnc
the ramp function is performing an implicit float cast on vector input, that means, it will take the first component only. You schould get the same results, if you are using v@P.x instead of v@P (but with v@P.z you will get another result).
The other thing is, that the ramp function is expecting values between 0 and 1, so it uses modulo one by default. For example 3.75 will be mapped to 0.75 and -0.1 will be 0.9.
