Fliptank fatal error
Alice_
Hi !
I am a beginner. Houdini crash when I try to work with fluids. I just created a flat tank, and just to look at the differents nodes, I cliked on the node fluid_compress1 in the fliptank_fluid and a get the "1460: Fatal error: Segmentation fault
Saving application data to C:/Temp/houdini_temp/crash.splashdown_01.alice_1460.hipnc"
The last time the fatal error occured when I changed the particules separation to set 3. Before I had other fatal errors in differents operations but always with fluids.
A friend built my computer recently, maybe there is something wrong with it. I didn't have any problem like this with bellowy smoke tutorial or procedural ground before.
Could you help me please ?
I have attached my computer config.
Thank you !
