dupevfx Posted November 12, 2020 Share Posted November 12, 2020 Hey all, I have a whole solaris setup and ready to render, I'm trying to do a slicker multi-shot workflow but I cant seem to get render frame ranges per shot. On the render settings node you cant specify the range, only on the very end USD_ROP node can you specify this. I've tried injecting metadata using 'storeparametervalues' for the start/end frame but I cant seem to use that information down in the USD_ROP (blue). Currently I'm using a switch to switch between my two shots here (orange). I'm relatively new to Houdini so I may just be missing something obvious but in the USD_ROP frame range I've tried: $shotStartFrame /HoudiniLayerInfo.shotEndFrame (this happens when you drag the value from the scene graph) Any help at this stage would be amazing. Thanks all Quote Link to comment Share on other sites More sharing options...
