sanostol Posted November 12, 2006 Share Posted November 12, 2006 This time I tried vop. I want to normalize point normals. the network is easy, a global variable node is connected with N to a normalize node, that leads to the output N. but this gives me following error message: what I'm doing wrong here, what is so special with normalize, multiply constant for example does work like expected martin Quote Link to comment Share on other sites More sharing options...
B.Walters Posted November 13, 2006 Share Posted November 13, 2006 Have you declared that variable, nvec? i.e. vector nvec = normalize(N); Quote Link to comment Share on other sites More sharing options...
sanostol Posted November 13, 2006 Author Share Posted November 13, 2006 Hi, Do I have to declare a variable when using vops, I thought the global variable node does all. If I have to do it in vop, how can I ? The other thing is that it does work with other operations, like multiplication. martin B.Walters said: Have you declared that variable, nvec?i.e. vector nvec = normalize(N); Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted November 13, 2006 Share Posted November 13, 2006 sanostol said: This time I tried vop. I want to normalize point normals.the network is easy, a global variable node is connected with N to a normalize node, that leads to the output N. but this gives me following error message: what I'm doing wrong here, what is so special with normalize, multiply constant for example does work like expected martin Are you calling your function "normalize"? If so, don't: you'd be calling your function from inside the function itself, which would explain the recursive error message... VEX does not support recursion (neither does any other shading language I know). If this is the case, rename your function. Failing that, post a simplified version of the problem so people have a chance to diagnose it. Quote Link to comment Share on other sites More sharing options...
sanostol Posted November 13, 2006 Author Share Posted November 13, 2006 That was the solution, thanks, good to know. martin Quote Link to comment Share on other sites More sharing options...
B.Walters Posted November 14, 2006 Share Posted November 14, 2006 I'm sorry I misread you, I thought you meant VEX not VOPs! Oops! Quote Link to comment Share on other sites More sharing options...
sanostol Posted November 14, 2006 Author Share Posted November 14, 2006 no problem B.Walters said: I'm sorry I misread you, I thought you meant VEX not VOPs! Oops! Quote Link to comment Share on other sites More sharing options...
