Assigning Hotkeys to Shading Modes
Is there a way to assign hotkeys to specific shading modes in the viewport? I know I can use W to toggle between wireframe and the last selected shading mode, but I'd like to have specific hotkeys for Wireframe Ghost, Flat Wire Shaded, etc. If I use Ctrl+Alt+Shift+LMB, I get a prompt saying the hotkey couldn't be created.
BTW, would also be nice to assign hotkeys to Hide Other Objects/Ghost Other Objects, but I'm seeing the same problem there.
Thanks!
You can write some Python code and call these functions inside a shelf tool and assign a hotkey to this shelf tool that can be constrained to SceneViewers only or global depending on how you want to execute them.
You can get the viewport under the mouse also. I just get the first available SceneViewer for my workflow.
def currentViewportSetToWireframe():
    with hou.undos.disabler():
        desktop = hou.ui.curDesktop()
        viewport = desktop.paneTabOfType(hou.paneTabType.SceneViewer)
        if viewport.isCurrentTab():
            view = viewport.curViewport()
            displaySet = view.settings().displaySet(hou.displaySetType.DisplayModel)
            displaySet.setShadedMode(hou.glShadingType.WireGhost)
def currentViewportSetToHiddenLineInvisible():
            displaySet.setShadedMode(hou.glShadingType.HiddenLineInvisible)
def currentViewportSetToFlatShaded():
            displaySet.setShadedMode(hou.glShadingType.Flat)
def currentViewportSetToFlatWireShaded():
            displaySet.setShadedMode(hou.glShadingType.FlatWire)
def currentViewportSetToSmoothShaded():
            displaySet.setShadedMode(hou.glShadingType.Smooth)
def currentViewportSetToSmoothWireShaded():
            displaySet.setShadedMode(hou.glShadingType.SmoothWire)
For changing the visibility of other objects, you might have to call an Hscript command in Python.
