Pop source
yujiyuji
Hi there !
Let's break it down a bit, and start just by emitting particles from frame 30
To do that, we can use a comparison with the current frame
"Is the current frame above 30"
So this is really simple ↓
@Frame >= 30 // The equal to make sure that it is true as soon as frame 30 is reached
This will evaluate as 0 before frame 30, then 1 at the frame 30 and after.
For emitting below frame 40, the logic is the same, with the comparison sign changing direction
@Frame <= 40
But you want above frame 30 and below frame 40
There is an "and" for this, the double ampersand → &&
So those two separate expressions becomes
@Frame >= 30 && @Frame <= 40
Hope that helps !
  • Thanks 1
