Flat Tank disappearing mesh
robert5
I have a problem with the Flat Tank Meshing, when I reduce the influence scale at some point the mesh of the flat tank disappears and I can only see the Splash mesh. The problem ends when I Increase the influence scale over 2.5 but then it not seems water. The particles in flip simulation are correct and the particle separation value is really low. If anyone knows what can be the problem please HELP ME!!!
I attach the flipbook to see that.
Thank you very much.
