Wrangle ch-slider standard value
Follyx
Yup :)
go to edit the node's parameter interface.
First check that the value range is not locked, its the small lock icons on the left and right side of the range,
about 3/4ths down on the right side panel of the edit parameter interface window.
Then go to the 2nd tab on the right panel (Channels), select the parameter you want to edit in the middle panel
and type in the desired default value in the right panel
