instance SOP alternative in Solaris?
While trying to bring in the moana island scatter data into LOPs, since each point data has its own obj filepath attribute to scatter stuff; i was wondering how i can use these with the instancer LOP within Solaris and make it work since it has the "name attribute" parameter. i tried using the instance Sop within the "sop create" and even tried but it keeps crashing, running out of ideas at this point. I even tried instancing within SOPs and using "sop import" within Solaris but no luck another crash.
tldr - how to scatter lots of objs with the help of filename string attribute on each point cleverly without having to manually bring in each obj file within Solaris?
thank you!
