Follyx Posted December 13, 2020 Share Posted December 13, 2020 sometimes my nodes have small blue i icon. If I click on the info it says that a node was or is copied. But canot reproduce it, in just copying a node. So whats going on here? Quote Link to comment Share on other sites More sharing options...
acey195 Posted December 17, 2020 Share Posted December 17, 2020 (edited) I guess its nodes that are "reference copies" you can make them by right clicking on a node, and then under actions edit: The reason you may want to use reference copies, is for when you want 2 nodes to behave exactly the same, but are in different places in your network. The difference with "normal" copies, is that it will also create parameter references for every controlling parameter on the node. Edited December 17, 2020 by acey195 1 Quote Link to comment Share on other sites More sharing options...
Follyx Posted December 18, 2020 Author Share Posted December 18, 2020 Good morning, perfect. That was it, never beeing aware of it... Thank you Quote Link to comment Share on other sites More sharing options...
