Correct workflow for adding Custom Velocity Fields to H18.5 Pyro SOP solver
mrkmmvl
Hi guys, I'd like to ask what is the right way of adding a custom velocity field into the pyro solver. Previously I used to add a new volume source that only brings in the velocity and merge it with the density source in the pyro solver.
However, I'm not sure how to do it with the new Houdini 18.5 updated Pyro solver since the inputs changed.
Thank you!
