Same value in an attribute.
I'm not quite sure if I understand your question right but,
you can drop down an "attribute create" node and create a new attribute for other points with a new name. or you can create a "attribute randomize" to give your points random attributes.
Points can have multiple attributes with multiple values.
attribute create:
set Group Type to Points.
set Group to which points should receive new value. (This should be setup the same way as the attribute. Such as if attribute "a" is a float, "Type" should be float. If it's a vector, "Type" should be vector)
Attribute Wrangle:
set Group to points that should receive new value
get attribute and define value
i@a = (value);
Attribute Adjust Integer/Float/Vector:
Which attribute
Set constant value
All these have a similar result to this:
