Segment A Curve
B.Walters
I need to segment a curve (poly or nurbs) into multiple primitives. By default, a curve is just a single primitive.
My ultimate goal is to birth particles from a curve weighted by an attribute. The Source POP will do this for me automagically, except it requires the distribution weight attribute to be of primitive type.
Any ideas?
Does the Carve SOP work? Keep both inside and outside.
All too well! Thanks Edward!
And for anybody else whose curious, here's an alternative solution I just discovered:
1-resample the curve
2- point the normals for each point on the curve to it's neighboring point
3- delete the last point
4- copy a line segment that's pointing down the +Z axis onto each point. The length of the line segment should be equal to the length of the resample.
This method is a bit rough on the edges (a few over-hanging points), though.
