guache Posted January 20, 2021 Share Posted January 20, 2021 (edited) I have a bunch of polys, some of which have "thin" parts: long, linear, protruding features. I want to remove them. I can't select by area, because 1) there are polys which are small, but don't have these "thin" parts, 2) I want to keep the non-thin parts of all polys and remove only the "thin" parts. The best definition of what I mean by "thin" is: "the part of the poly where the distance from one edge to another, not-directly connected edge, is below some number". Any ideas? Edited January 20, 2021 by guache Quote Link to comment Share on other sites More sharing options...
Librarian Posted January 20, 2021 Share Posted January 20, 2021 @guache "Intrinsic " Unpack and Pack ....over primitives code than SPLIT SOP och expr---- @volume>`chs("range")`---or Post File for Fun. float bounds[] = primintrinsic(0, "bounds", @primnum); //Minimum All vector min_all = set(bounds[0], bounds[2], bounds[4]); //X_max vector x_max = set(bounds[1], bounds[2], bounds[4]); //Y_max vector y_max = set(bounds[0], bounds[3], bounds[4]); //Z_max vector z_max = set(bounds[0], bounds[2], bounds[5]); float X = distance(min_all, x_max); float Y = distance(min_all, y_max); float Z = distance(min_all, z_max); //to Size vector size = set(X, Y, Z); //to Volume float volume = X * Y * Z; //export v@size = size; f@volume = volume; Quote Link to comment Share on other sites More sharing options...
