DerQualle Posted January 20, 2021 Share Posted January 20, 2021 Hi, im trying to render a simple pyro explosion with Vray. My steps are pretty simple for now: I added a pyro sim from the shelf tools to my scene gave the sim a material that has the Volume Grid shader https://imgur.com/a/rdjdjtY This is what i end up with. Inside the Volume Grid under Fields i enable Fire, and use the flame attribute, but nothing changes. I have full controll over the Smoke parameters in the Smoke tab, but nothing changes when adjusting parameters in the Fire Tab. Here are my Volume Grid Settings: https://imgur.com/a/kBtFDZm Im sure im just forgetting a step or something. I would appreciate any help. Thanks! pyro_vray_test.hiplc Quote Link to comment Share on other sites More sharing options...
DerQualle Posted January 21, 2021 Author Share Posted January 21, 2021 Found the issue myself. Vray 5 fire is broken Quote Link to comment Share on other sites More sharing options...
Alka Posted February 18, 2021 Share Posted February 18, 2021 On 21/1/2021 at 10:14 AM, DerQualle said: Found the issue myself. Vray 5 fire is broken What do you mean? Is it impossible render Flames with Vray 5? Quote Link to comment Share on other sites More sharing options...
