Procedurally set bend capture region?
bentway23
Would there be a way to procedurally set the capture region for a bend deformer, for instance if you're using it in a for loop for the same object but with different sizes/rotations? I guess the main question would be figuring out its angle, as bounding box and centroid expressions could do most of the placing and sizing (except if the object was rotated the bounding box size wouldn't be accurate).
  • 3 weeks later...
The easiest way to do it is set a loop to iterate over pieces and then inside the loop write the relevant attributes (bounds, direction, bend angle) to detail attributes. Then you can reference them inside the bend node with the detail(input, attrib, component) expression. Then delete the attributes at the end of the iteration.
Sorry, I didn’t see it was already solved
