Jmg07 Posted February 14, 2021 Share Posted February 14, 2021 Hi. I'm trying to model a needle. The cylinder is created by sweeping a circle down a line. Then polyextruding the resulting tube so it has a bit of thickness to it. I'm stuck trying to cut the end off diagonally. I'm just after some confirmation the polycut or polysplit would be appropriate nodes to do this (i tried using them but lucked out). Or if there are better suggestions that'd be great. Thx Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted February 14, 2021 Share Posted February 14, 2021 The shear transformation can create an angle. needle.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted February 14, 2021 Share Posted February 14, 2021 Hi, you can use boolean with a big box for example and apply bevel on the abseams (if wanted). Here is an example needle.hipnc 1 Quote Link to comment Share on other sites More sharing options...
