Follyx Posted February 17, 2021 Share Posted February 17, 2021 how to merge one take into another? The helpfile says: If data is active in the current take, and you merge in a second take that also has the data active, Merge Take will use the current take’s data. Merge Take (with override)will override the current take’s data with the data from the second take. Wich data should be active? Where can I toggle it and also the override function. Couple of times I opened a similiar thread: but now on 18.5.462 the last post from "TLOEFFLER" also dont work anymore, do I use it wrong? ;-): I simple add the script into a python shell and.... could someone give me some advice please? Quote Link to comment Share on other sites More sharing options...
