Mozzarino Posted February 18, 2021 Share Posted February 18, 2021 I'm having an hard time telling my ROP Geometry Output to cache simulations one frame at a time. I did as the documentation says: check the "All Frames in One Batch" parameter, but once the first work (first frame) ends, the next ones take like 1 sec each and the output has 1KB.... I've switched to a ROP Fetch TOP pointing to a file cache SOP and set the "Evaluate Using ROP Node Configuration" parameter and it works fine (displays only one work and caches all frames sequentially). Am I doing something wrong? Quote Link to comment Share on other sites More sharing options...
