POP stream/group in wrangle
Jsmidlow
I assume your first input is set to Myself
is your wrangle connected in that stream?
if it is then you don't have to do the if statement as POP wrangle automatically filters the stream group
if it is in different stream then because of the same reason it may not run on particles of "stream_main" therefore none of the particles of different stream will satisfy the condition
if you don't want it to be automatically using only current stream particles use Geometry Wrangle instead of POP Wrangle and then it wouldn't matter which stream it plugged into, it'd be unnecessary in this case though
