Working with custom VEX surface shaders
haki
I've some experience with VEX in SOP land but I'm new to Mantra shading and I want to get better at writing vex shaders. What would be the modern way of doing that?
In particular, I'm not entirely sure if I could simply write my code and hit compile (the way I would with OSL in RenderMan) without ever leaving Houdini or restarting the renderer for that matter.
For instance, I managed to compile the following from a vfl (a modified sidefx example) into an HDA (.\vcc -l "%HOME%\houdini18.5\vex\hcartoon.hda" "%HOME%\houdini18.5\vex\hcartoon.vfl") and it's available under /SHOP/Digital Assets and it works.
#include <shading.h>
#pragma opname		hcartoon
#pragma oplabel		"HCartoon"
#pragma opicon		SHOP_surface
#pragma label	colora	"Color A"
#pragma label	colorb	"Color B"
#pragma hint	colora	color
#pragma hint	colorb	color
#pragma hint	Cd	hidden
surface
hcartoon(
	vector colora={0.2, 0.5, 0};
	vector colorb={0, 0.2, 0.8};
	vector Cd=1;
	vector Cx;
	illuminance(P){
		Cx = Cl;
		shadow(Cl);
		if (Cl == Cx){
			Cf = colora;
		else{
			Cf = colorb;
However, isn't there a more straightforward way? Do I always have to compile to HDA and write all those pragmas? I was hoping for something like an attribute wrangler approach.
So, there's the Surface Shader Builder (vopsurface) that I have to admit I don't quite get as far as writing code goes. Snippet? Inline? How about inputs and outputs in it? Surely not with pragmas in there, right? I tried with a snippet, got a compile error 'Invalid return type (surface)'.
If anyone can help me with it, that'd be awesome! Thanks,
Hristo
