AntoineSfx Posted March 2, 2021 Share Posted March 2, 2021 I have a set of planar curves that I would like to polyextrude and assign a bricks material to. So I need to have the u component along the curve (closed) and the v along the extrusion side. Can you suggest a way to do it so that the brick size is consistent across different curves with different perimeter and extrusion depth ? Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted March 2, 2021 Author Share Posted March 2, 2021 So I found that Sweep SOP has several options to output the UV I wanted, so I ended up building it using Sweep SOP instead. 2 Quote Link to comment Share on other sites More sharing options...
ryew Posted March 2, 2021 Share Posted March 2, 2021 Thanks for following up to post the solution and help others seeking a solution to the same issue in the future, Antoine Quote Link to comment Share on other sites More sharing options...
