iasm6419 Posted March 3, 2021 Share Posted March 3, 2021 How to change the order of points ? sample_test.hipnc Quote Link to comment Share on other sites More sharing options...
davpe Posted March 3, 2021 Share Posted March 3, 2021 (edited) Sort SOP it can reverse, or sort points / prims by different criteria in your case i believe it would work well combined with resample SOP (it generates @curveu attribute that can be used to sort points) Edited March 3, 2021 by davpe Quote Link to comment Share on other sites More sharing options...
iasm6419 Posted March 4, 2021 Author Share Posted March 4, 2021 On 2021. 3. 4. at 오전 1시 14분, davpe said: SOP를 정렬 하거나 다른 기준으로 포인트 / 프림을 정렬 할 수 있습니다. 귀하의 경우에는 리 샘플 SOP와 잘 결합 될 것이라고 생각합니다 (포인트 정렬에 사용할 수있는 @curveu 속성을 생성합니다) Thank you very much, let's try Quote Link to comment Share on other sites More sharing options...
