kfu Posted March 5, 2021 Share Posted March 5, 2021 Anyone had this issue when you do some color correct before the ocio transform node, the output image looks way different than the actual view in Houdini? But if I disable those color correct nodes, it works perfectly fine. Here is the image about what I mean, when I disable the contrast and add nodes, it works. When I enable them, the output images looks different. Any idea why this happens? Quote Link to comment Share on other sites More sharing options...
schwungsau Posted March 13, 2021 Share Posted March 13, 2021 it depends if save it as jpg or exr etc... or what LUT/colorcorrection the image viewer is setup ? but first you should start lear about linear color workflow. Quote Link to comment Share on other sites More sharing options...
