Pivot From Sop
MENOZ
hi all.
i have a problem, it's enough simple but i can't get out of it..
say a have a controller, i move my pivot at a certain position, in sop.
now i want, in obj level, the ability to move, rotate my object not starting from 0 0 0 grid, but from the position i defined in sop.
if i move the pivot in the obj level and collapse into a subnet, i have the same problem..
how can i do?
i can make a digital asset and add the parameters i need, but i have not the handle.. i need the handle!
thanks
edit:
ok i see that moving pivot form obj, and making it a subnmet and create a DA with my parameters it work, but if i use parameters form SOP it doesn't...
The "pivot" in SOPs is the local origin. So just put down a Transform SOP and translate it such that your "pivot" is at the center of the object.
yes, but doing so my geometry result... translated.
sumone, yes, it works with expressions.
thanks everyone
