hda to get called back when hip file saved?
catchyid
hi,
I am developing an hda, and some of its parameters need to update themselves when the file is saved (e.g. if the user changes the file name, then i need to run a code in hda to update some paths accordingly). I found some event handlers (e.g. on Created, On Loaded, ...), but could not find a handler such as (On File Saved?) ...
thx,
you can use hou.hipfile.addEventCallback()  to register a callback for when the hipfile is saved
you can add this code in the HDA python module, or (depending on what you want to do), put it in the 'On Created' event handler to register it when the node is created, or the hipfile is loaded.  You will probably also want to check for any existing callbacks before setting a new one
https://www.sidefx.com/docs/houdini/hom/locations.html#scene_events
https://www.sidefx.com/docs/houdini/hom/hou/hipFile.html
  • Like 2
