anbt Posted March 10, 2021 Share Posted March 10, 2021 Hello Hello, I have this Point Replicate set to 20. I would like to not have 20 for each point but for example between 10 and 20. Some points would be replicated 10, other 13... etc.. till 20! It should be a super simple line of vex but can't make it work. Thank you Quote Link to comment Share on other sites More sharing options...
Gorrod Posted March 10, 2021 Share Posted March 10, 2021 Toggle on "Generate from Attribute" and create an attribute that ranges from 0.5 to 1. Where 0.5 will create 10 points and 1 will create 20. Quote Link to comment Share on other sites More sharing options...
eikonoklastes Posted March 10, 2021 Share Posted March 10, 2021 Slight modification to what Gorrod just posted. To keep things cleaner, set the Points per Point to 1, and define an attribute than returns between 10 & 20 randomly per point. The new Attribute Adjust Integer SOP is perfect for this. 1 Quote Link to comment Share on other sites More sharing options...
anbt Posted March 10, 2021 Author Share Posted March 10, 2021 Amazing guys, thank you very much Quote Link to comment Share on other sites More sharing options...
