how to 'polywire' the stretch constraints between my stitch points?
anbt
Hello,
How would you polywire or visualise the stretch constraints between my stitch points?
It is a vellum weld on the screenshot but is a vellum stitch in reality.
So I can see them when I simulate. I mean not with the vellum visualisation but in real, to actually have them part of what you see in the simulation.
Cheers
Edited by anbt
in your Vellum Constraints you can specify Output group name for your stitch constraints
then after sim can use Blast SOP on constraint (second) output to delete everything except for your group
and append Sweep SOP, change surface type to Round Tube and tweak the radius
merge with your primary geo
