Copy-to-points RBD-Packed dopnet does not work
nassosy123
I'm trying to randomly copy/instance a bunch of objects into a scattered point-cloud using the new "Attribute from pieces" and "Copy to points" nodes.
I want to manipulate them in a simple DOPnet sourcing them with "RBD Pack Object" and solving them using the "Rigid Body Solver",
but the solver doesn't seem to find the neither the "name" attribute or a compatible geometry.
I can't figure out what is wrong with it.
Can anyone help?
(tried with SOP level RBD solver and it works fine. still i want to use a DOPnet)
thanks in advance.
(using Houdini 18.5.408 on win10)
swarm-01.zip
On the bullet solver, in Advanced, set Sleeping Time to zero.
Some of the pieces are moving so slowly that they get de-activated over time.
For the dopnet part, you need a unique name per pieces, you can create that from the ID
s@name="piece_"+itoa(i@id);
I attached an example, also adding some initial velocity to the pieces.
swarm-02.zip
thanks for Sleeping Time hint!
As for the DOPnet, i opened the file and it still didn't work,
Then i deleted and re-created the RBD Packed Object node and everything worked like a charm, even without your modification.
(propably a glitch, don't know)
thank you for your help. i'm gratefull.
