RedbeansandRice Posted March 16, 2021 Share Posted March 16, 2021 Hello all! I have been trying to figure out how to dynamically update the constraints in a vellum constraints property node based off of the distance of the vellum object from a given point in space, but I cant figure out how to make this calculation dynamically in this context. I can measure the distance before and after the vellum solver with a distance node but they only give me static values in the solver context so I dont know how far things are once theyve moved. Havent been able to get xyzdist to work either. Any help would be greatly appreciated as this project is very important to me!! Quote Link to comment Share on other sites More sharing options...
underscoreus Posted March 16, 2021 Share Posted March 16, 2021 Heyo, If you are able to share your hip file that might be helpful to see more specifics. However, as a start, I made a small test in SOPS and was able to make xyzdist work in creating a dynamically changing distance. I'm not that used to using xyzdist so I don't know if this is the most optimal setup of it, I'm more of a nearpoint guy myself though this is way more accurate. Here is the vex code I used: int prim; vector uvw; vector c = getbbox_center(0); vector p = xyzdist(1, c, prim, uvw); vector pos = primuv(1, 'P', prim, uvw); float dist = distance(v@P, pos); f@test = dist; The "vector c" part is not that important, it's just where I choose as the origin of my measurements, you might want to use v@P or something similar. Only other thing to note is that this is a wrangle where the thing you are measuring from is in the first input of the wrangle and what you are measuring to is in the second input. Hope this can be of any help. Quote Link to comment Share on other sites More sharing options...
