tuberkulum Posted March 24, 2021 Share Posted March 24, 2021 (edited) Hello, I need help from a noob with PDG and imagemagick node: 1) a) When the "concatenate" mode is on, everything works predictably and as it should, it glues the supplied files into a mosaic, you can adjust the resolution of the final image. As soon as I turn off the "concatenate" mode, the resolution adjustment of the final mosaic stops working, and the same low resolution is obtained (about 500-600 pixels). As I understand it is necessary to set the resolution in Custom Imagemagick? But how to write it there, what is the syntax, tried many options, all the errors. 2) What other modes are there besides "concatenate"? and how to register them? Forgive in advance if not that forum thread. Thanks for the help! Edited March 25, 2021 by tuberkulum Quote Link to comment Share on other sites More sharing options...
