bentraje Posted March 25, 2021 Share Posted March 25, 2021 (edited) Hi, Is there a way to advect points on a SOP level? I understand that there is a VDB Advect Points. I couldn't get it to work. Even if I do, I think its a bit round about way to "advect" points, at least based on the documentation (i.e. uses vdb from polygons, vdb analysis). Just wondering, if there is a simple node/process to do this like the "Pop Advect by Volume" in the DOPS level. Edited March 26, 2021 by bentraje Quote Link to comment Share on other sites More sharing options...
markinglevfx Posted March 25, 2021 Share Posted March 25, 2021 Use the SOP solver and a point VOP/wrangle to sample a vel field at each point's position. You can then add that vector to P to get the next frame's position. advect_in_SOPS_v001.hip 1 Quote Link to comment Share on other sites More sharing options...
bunker Posted March 25, 2021 Share Posted March 25, 2021 just FYI: the solver SOP, is a SOP solver it's using a DOP network inside, so you'll be using DOPs anyways. 1 Quote Link to comment Share on other sites More sharing options...
bentraje Posted March 26, 2021 Author Share Posted March 26, 2021 Hi @markinglevfx @bunker I only have the indie and noncommercial version. So had to ask a colleague to open it for me. The file works as expected. It also works with vanilla volumes (i.e not VDB) although I seem to have more appealing result with VDB. Thanks have a great day ahead! Quote Link to comment Share on other sites More sharing options...
