Copy to points problem
So i want to make a pillar but a i have a problem when i copy object to points they need to have de same angel as the surface but then this happend.
can someon help me with this?
Edited by Obiteke
Make sure the points you are copying to have the same normals as the surface you want the geometry to follow as well as give the points you are copying to an "up" vector attribute. Try having the vector be 0,1,0 to begin with and maybe change it if it does not work. If you upload your hipfile it'll be easier for people on here to have a look at it so for now the advice above is just speculation on how to solve the issue.
