flowerdealer Posted December 18, 2006 Share Posted December 18, 2006 Hi, I'm trying to get opaque colored shadows projected into other geometry. So far I've gotten this result by using transparent geometry with a vex layered surface attached with the alpha set to 0 and the transmit value set to whatever color I choose. I get the expected result if I'm projecting over an object shaded in white, but if I change the color it mixes with the new color. I tried to create a new shader in VOPS that uses the shadow matte to cut out the color from the region I want to maintain for the opaque shadows, but the problem is that because I set the layered texture's alpha to 0 in the projecting object, the alpha is black. How else could I do this? I have seen the Ubershadow shader, but I would like to be able to color the shadows based on the color of projecting objects, not some arbitrary values. Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
edward Posted December 20, 2006 Share Posted December 20, 2006 Try just directly using a Is Shadow Ray VOP instead of the Shadow Matte VOP. Something like this: Is Shadow Ray -> Integer to Float -> Complement -> Output (Af) Quote Link to comment Share on other sites More sharing options...
flowerdealer Posted December 20, 2006 Author Share Posted December 20, 2006 Hi, I've tried doing what you're saying but the shader doesn't evalutae as an opaque black and white matte. Again, I'm using filtered shadows with the casting object using a material with a certain transmission color, and 0 alpha. Am I doing something wrong? Quote Link to comment Share on other sites More sharing options...
edward Posted December 20, 2006 Share Posted December 20, 2006 Hmm ... it looks like a ray is not considered as "shadow" if it's being transmitted through a transparent surface. What about doing your rendering in multiple passes then? Pass 1: White receiver objects receiving the coloured shadows Pass 2: Opaque Shadows with alpha = 1 with a shader that just does the Is Shadow Ray part. Then you can use the alpha from pass 2 with pass 1? Quote Link to comment Share on other sites More sharing options...
flowerdealer Posted December 21, 2006 Author Share Posted December 21, 2006 Yes, I guess I could always do that, although I'm trying to learn vex shading in vops and was trying to figure it out. Any other ideas? Thanks for your help anyway! Quote Link to comment Share on other sites More sharing options...
