Uniform Texture Coordinates
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Ok as I suspected when I put the timers in I found that the bottle neck was in the actual smoothing loop.
I've totally rewritten that part and used a pre caching loop that totally speeds things up. Its about 3 - 4 times quicker. It still chugs through at about 0.5 secs per loop for 10,000 points, but its hard to see any way to make it even quicker. Open to ideas though.
Probably need to put some interrupts in and find a better way to show the progress rather than using the console.
I'm thinking of adding a float param that I update as the sop cooks, but that seems a bit naff.
@Edward, is there a proper progress bar I can access in the hdk?
UVuniform.zipFetching info...
  edward said:
I'm not really sure but check out UT_Interrupt.h.
But 3-4 times quicker sounds like quite a bit of progress! :)
Yeah, feels much better now, you have to wait a bit but at least it feels like the handbrake is off! :rolleyes:
Added a proper progress bar too now, that helps a lot, at least there is something pretty to watch...
thanks for the pointer, UT_Interrupt was the one. I've used it before but never realised it handled the progress dialogue too. Cool.
Edited by sibarrick
  edward said:
The simplest way is to copy the .dll into your $HFS/houdini/dso directory and restart Houdini.
Just have to watch which version of Houdini you are using... this is compiled for (H8.1.760, windows) it should work for other windows builds around that number, but I can't be sure which ones.
  zoki said:
ok
thanks
I loaded it now I just need to figure out how to use it :D
Copy the config stuff into your $HOME/Houndini8.1 directory and then you should get the help. Which might help.... :unsure:
FAQ
Why use a chain of sops and not just one?
2 reasons
1. Speed, each one uses a slightly less dense grid to do the uniforming process - the grid density is based on the median edge length in uv spce - hence each one cooks quicker than the previous one. I could make that all internal but its extra work B)
2. It seems to be quite hard for the alogorithm to find a solution with a really dense grid so as each sop uses a looser grid it gets better at being able to move points far enough to get a good result.
Does it anly work with point uvs? and why?
It doesn't do vertex coordinates, why? Laziness :rolleyes: Its much more tricky to deal with vertex coordinates so I'm leaving it to the user to convert back to vertex coordinates at the end. 2 sops will help with this attribute promote and attribute copy. Here's an example
sphere_uvuniform.zipFetching info...
Can it sort out overlapping uv's?
No. Unfortunately bacause it just uses a deforming grid to do all the work any uv's that are overlapping in the original will stay that way.
Notes:
UV's must start in the range 0-1 and be point uvs
In general the only parameters you will probably need to change are the max number of iterations and the retransfer every # number. You will probably always want that at a value lower than the max iterations - say a quarter or half the amount - perhaps lower, just play with that one.
Turn up the max iterations until you don't see any more changes in the result. If it gets too high and too slow start using a chain of sops.
Known Bugs
Just found 2 bugs.
1. When the primitive normals are the wrong way around - ie facing inwards it won't work.
2. At least one pelt I tried only half works, one half of the mesh is not being effected. Or more precisely the top left quarter and the bottom right quarter in uv space. I haven't figured out why yet.
But if anyone tries this sop and finds more situations like this please post them so i can find out what is going on.
ta
Edited by sibarrick
I tested this and its definetely a big bug. I can't find the cause yet though, let alone fix it. The algorithm should work in this situation, but for some reason the grid isn't picking up the distortion. You can turn on the visualise button and see a symmetrical colour pattern on the mesh but then after that something goes wrong. I now have a mesh based on your cup one that doesn't do anything - ie the sop just doesn't cook, so I need to dig around at quite a low level to find out what is going wrong.
  LEO-oo- said:
I tried the SOP with the cup-sample from this thread. It seems the UVuniformSOP displace the UVs slightly and the symmetrical UV-layout is damaged.
cup_uvuniform.zipUnavailable
Well I found the problem - its the way the GQ_Detail is built which means that the edges don't necessarily always go in the same direction over the entire uvGdp, which is fundamental to my quick search method.
The fix at the moment is to use the slow search and reverse polys that are flipped in uv space - so this is not ideal. There must be a proper fix for this so I'll keep playing til I get something that works.
Thanks for the update. The problem seems to be gone :)
But I have an other specific now. I tried the SOP on my raptor-model. The UVs overlap in some areas - please look at the picture. Right side is the pelted geometry only and on the left side with the UVuninformSOP.
And the result of the UVuniform-SOP in the viewer.
