sb526 Posted May 25, 2021 Share Posted May 25, 2021 I am trying to Sort some points on the primitives I have. As you see from the image I need to Sort the points to first grab all of the first ones on each prim (0,6,11,16,21,etc). Then once I reach the spiral segment length (10 in this case), append the next segment of the spiral. One way I can see is using Sort by proximity to a point but I don't know how to make this point dynamic. But I am struggling to reference origin pt coordinates (0) into the Sort node. Alternatively, it's a Point Wrangle with some VEX code & some counters. Are there any off-the-shelf tools that can do this that I am missing? Thanks! Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 26, 2021 Share Posted May 26, 2021 (edited) can you upload your splines ? Would prefer to run my logic thru your splines than my mock up that doesn't match your scene exactly. Edited May 26, 2021 by Noobini Quote Link to comment Share on other sites More sharing options...
Fenolis Posted May 28, 2021 Share Posted May 28, 2021 Have you tried using the Add node? You can enable Point 0 and use its position (via point(...) expression in Sort) if your origin isn't static. Once you have sorted by proximity, you can use another Add node, in the Polygons tab > By Group, Add "Groups of N points". Quote Link to comment Share on other sites More sharing options...
