yujiyuji Posted June 3, 2021 Share Posted June 3, 2021 Please look at sample_1 and sample_2. I don't understand why if I connect node like sample_1 is working but sample_2 is not working. Can anyone logically explain why we need to use ADD node? Why if I connect aanoise to P directory is not working properly. I Quote Link to comment Share on other sites More sharing options...
Shantanu Posted June 9, 2021 Share Posted June 9, 2021 please check the geometry spreadsheet ones. the al noise require position to apply noise on the grid. if you apply a noise on grid without giving a position it will apply on each point randomly check the spreadsheet of the sampan one. in sample 2 you are adding position to to the noise then its giving you the fine result Quote Link to comment Share on other sites More sharing options...
Fenolis Posted June 10, 2021 Share Posted June 10, 2021 @Shantanu This topic is a duplicate and has already been answered: Quote Link to comment Share on other sites More sharing options...
