yujiyuji Posted June 3, 2021 Share Posted June 3, 2021 Please look at sample_1 and sample_2. I don't understand why if I connect node like sample_1 is working but sample_2 is not working. Can anyone logically explain why we need to use ADD node? Why if I connect aanoise to P directory is not working properly. I Quote Link to comment Share on other sites More sharing options...
flcc Posted June 4, 2021 Share Posted June 4, 2021 Noises are just a functions that returns a value between 0 and 1 (or -1 1 or -0.5 0.5) depending on the position. So by connecting a noise directly to the position you overwrite all position values between 0 and 1 (or -1 1 or -0.5 0.5), totaly loosing the original shape. It's why the correct qorkflow is to add the noise values to the orginal values. 2 Quote Link to comment Share on other sites More sharing options...
yujiyuji Posted June 4, 2021 Author Share Posted June 4, 2021 I got it!! Thank you so much!!! Quote Link to comment Share on other sites More sharing options...
