hindukush Posted June 9, 2021 Share Posted June 9, 2021 (edited) Hi everybody, there is a way to switch from low res to hi res with the new rbd tool?Using with proxy geometry if i change edge details the sim changes too. I would like to keep the same sim and change geo after like using dop/io and transform pieces. No success with transform pieces, and i menaged to get translation with copy attribute by name but no rotation. Carlo Edited June 10, 2021 by hindukush Quote Link to comment Share on other sites More sharing options...
Milad.Savar Posted June 9, 2021 Share Posted June 9, 2021 3 hours ago, hindukush said: Hi everybody, there is a way to switch from low res to hi res with the new rbd tool?Using with proxy geometry if i change edge details the sim changes too. I would like to keep the same sim and change geo after like using dop/io and transform pieces. No success with transform pieces, and i menaged to get translation with copy attribute by name but no rotation. Carlo maybe help u - about your problem make sure your name attrib in low and high object is the same RBD Hi-Low.hip 1 Quote Link to comment Share on other sites More sharing options...
hindukush Posted June 10, 2021 Author Share Posted June 10, 2021 Ty Ultraman! Yes i wasn't passing the name attribute after rbd sim. Finally i got it working using the transform pieces, plugging as template points the last output from rbd solver(the sop version), instead the simulated geo. thanks alot! Quote Link to comment Share on other sites More sharing options...
